Author Topic: Make an easy and cheap sheet metal slapper --  (Read 2991 times)
« on: May 26, 2013, 06:00:06 PM »
I needed  little bit more reach while doing some sheet metal work. My regular slapper was about 3" too short, so I made this. Cheap HF pry bar out of my road box and a scrap piece of 1/8" plate.
Grind or cut the plate to size with some rounded edges so as not to gouge the sheet metal, and then make it pretty with a flap wheel
Weld the pry bar to the plate -- done!!!
Sand and shape the plate accordingly, and then put a slight bend in the edge to facilitate accurate center hits on the slapper plate
Clean it up a bit and polish the bottom
Total cost? a few bucks, and it works just as well as a $50 name brand -- Good luck!
Re: Make an easy and cheap sheet metal slapper --
« Reply #1 on: May 28, 2013, 07:53:10 AM »
Good idea there. I never thought of doing that.
« Reply #2 on: May 28, 2013, 11:19:44 AM »
Used it yesterday -- works pretty well on 20ga steel. Makes nice smooth metal out of cratered panels.
« Reply #3 on: May 28, 2013, 02:10:01 PM »
I need to make a couple of them up for the Volvo.  I'll need to find a couple of sacrificial pry bars first. No way I'll do that to my MAC's.
« Reply #4 on: May 28, 2013, 06:39:17 PM »
Got a Tractor Supply Store near you? They usually have 'em for a few bucks in their cheap tool bins close to the cash register.
« Reply #5 on: July 13, 2013, 11:02:48 AM »
I have one made out of a leaf spring.
when I feel like it I might take an old pack apart and make some.
