Author Topic: Little Red Straws for Aerosol Cans & Rubber Retainers  (Read 1491 times)
Offline TxDoc
« on: February 01, 2012, 01:37:26 AM »
 First post, so this may be not be in the right area. This info may be as old as dirt, but I use these things daily.
 Even though WD-40 has its own straw attached to the can, now, other spray can products do not. So there is a source for the straws and a source for a rubber retaining device to hold the straw.
http://www.hold-it.net/ is the site for the rubber retainer. A HOLD-IT is a one-piece component used to secure "That Little Red Straw You Are Always Losing", to aerosol cans. With the ease of having your straw readily available to you, it reduces down time and frustration! HOLD-IT allows the straw to be attached to the container at all times.
HOLD-IT is made of an extremely durable rubber/elastic polymer which stretches to fit just about any size can. Therefore, our Product is adaptable to numerous products such as; Lubricants, Choke Cleaners, Electrical Contact Cleaners, De-greasers, Carburetor Cleaners, Rust Proofers, Contact Cleaners, Pesticides, Key/Lock Lubricants, Anti-Chillers, & Compressed Air Sprayers.
The straws come from:
http://www.littleredstraw.com
Re: Little Red Straws for Aerosol Cans & Rubber Retainers
« Reply #1 on: February 01, 2012, 08:45:13 PM »
simple solution that in most cases should cost noting use an elastic band or cut a band out of an inner tube
