Rebuilt a nice RODAC air driver ---
  • 3 replies
  • 1993 views
  • 2108
  • 364
« on: November 13, 2011, 09:31:33 PM »
I saw this little gem languish on ebay for a few weeks and finally decided that it needed a good home. Not unexpectedly, it showed up yesterday DOA. So today I took the thing apart and cleaned it. Apparently the previous owner tried to fix it and didn't reassemble it correctly --
A little worn, but these things are "sooooo" nice for removing stuck screws -- and for quick removal of fasteners. This looks to be an early 1970's model because the ID plate is just a sticker. Earlier models has metal plates --
The bit retainer is held on by a circlip --
Then the driver and power adjustment assembly is screwed off in a counterclockwise direction
This exposes the driver and clutch assembly --
Not a bit of grease in there --
Trigger assembly was installed wrong -
Retaining pin for the reversing switch assembly is punched out --
This is the gear assembly for the driver itself -- pretty cool design.
Trigger air metering valve is pushed out through an access port on the back
... and finally the air motor itself. Of course the previous "rebuilder" put the air vanes in upside down; hence no power.
Time to refurbish and rebuild this mess!!!
Some paint on the various componenets and the driver body --
Reassembling the air motor with the correct vane position
The gear cluster is greased and reassembled --
The clutch mechanism is reinstalled and greased --
The driver assembly is lubed and pre-assembled --
A test fit is made to ensure that the clutch engages and disengages properly --
Just to top it off, the power adjustment ring is polished up a bit to give the driver some contrast --
A quick test run with air, and this vintage driver is ready for another few decades of service --
Online rusty
  • 6871
  • 1743
Re: Rebuilt a nice RODAC air driver ---
« Reply #1 on: November 14, 2011, 03:18:33 PM »
I would have probably messed up putting that back together myself.
It looks great!
  • 521
  • 21
« Reply #2 on: November 21, 2011, 10:11:26 PM »
Another great write up Ray. How did you know things were backwards?
  • 2108
  • 364
« Reply #3 on: November 21, 2011, 10:56:34 PM »
The trigger pull was off because the trigger itself was seated way too far back on the control valve. You could only move it a slight amount. The vanes in the motor drum were obvious. They were not making a seal on the housing -- no seal -- no spin  -- no power --- LOL
