Author Topic: ORION / VII 2010  (Read 1595 times)
ORION / VII 2010
« on: August 20, 2011, 02:38:04 PM »
Report Date :   August 20, 2011 at 02:34 PM
NHTSA Campaign ID number :   11V421000
Vehicle Make / Model:         Model Year(s):
     ORION / VII          2010
Manufacturer: DAIMLER BUSES NORTH AMERICA, INC.   Mfr's Report Date: AUG 15, 2011
NHTSA CAMPAIGN ID Number: 11V421000   NHTSA Action Number: N/A
Component: ENGINE AND ENGINE COOLING
Potential Number of Units Affected: 96
Summary:
 DAIMLER BUSES NORTH AMERICA (DBNA) IS RECALLING CERTAIN MODEL YEAR 2010 ORION VII TRANSIT BUSES MANUFACTURED FROM NOVEMBER 2010 THROUGH JANUARY 2011, EQUIPPED WITH A CUMMINS ISB, ISX, ISC, OR ISL DIESEL ENGINE. THE V-BAND CLAMP ASSEMBLY, PART NUMBERS Q187684, Q187685, AND Q187686, USED TO CONNECT THE INLET AND OUTLET CONE SECTIONS TO THE DIESEL OXIDATION CATALYST (DOC)/DIESEL PARTICULATE FILTER (DPF) INCLUDE A T-BOLT WHICH CAN FRACTURE AND FAIL WHEN SUBJECTED TO STRESS OR LOAD. A FRACTURE OR FAILURE OF THE T-BOLT MAY CAUSE THE CLAMP TO LOOSEN AND THE INLET OR OUTLET SECTIONS ATTACHED TO THE DOC/DPF HOUSING TO DISCONNECT.
Consequence:
 IF THE INLET OR OUTLET SECTIONS DISCONNECT, HOT EXHAUST GASES CAN VENT PRIOR TO EXITING THE TAILPIPE, CREATING THE RISK OF COMBUSTION AND A FIRE. IF BOTH CLAMPS FAIL, THERE IS A RISK IN SOME APPLICATIONS THAT THE DOC/DPF HOUSING MAY DETACH COMPLETELY, CREATING A ROAD HAZARD.
Remedy:
 DBNA IS WORKING WITH CUMMINS TO IDENTIFY AND NOTIFY OWNERS OF THE RECALL CAMPAIGN. REPAIRS WILL BE PERFORMED BY AUTHORIZED CUMMINS DEALERS FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING AUGUST 2011. OWNERS MAY CONTACT CUMMINS AT 1-812-377-5000 OR DBNA AT 905-403-1111.
Notes:
 CUMMINS RECALL CAMPAIGN NUMBER IS C1154. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
ORION / VII 2010
