Author Topic: PIERCE 2011 ARROW XT, CUSTOM CONTENDER, DASH CF, IMPEL, SABER, AND VELOCITY  (Read 1058 times)
Report Date :   August 20, 2011 at 02:30 PM
NHTSA Campaign ID number :   11V422000
Vehicle Make / Model:         Model Year(s):
     PIERCE / ARROW XT          2011
     PIERCE / CUSTOM CONTENDER          2011
     PIERCE / DASH CF          2011
     PIERCE / IMPEL          2011
     PIERCE / SABER          2011
     PIERCE / VELOCITY          2011
Manufacturer: PIERCE MANUFACTURING   Mfr's Report Date: AUG 16, 2011
NHTSA CAMPAIGN ID Number: 11V422000   NHTSA Action Number: N/A
Component: ENGINE AND ENGINE COOLING
Potential Number of Units Affected: 18
Summary:
 PIERCE IS RECALLING CERTAIN MODEL YEAR 2011 ARROW XT, CUSTOM CONTENDER, DASH CF, IMPEL, SABER, AND VELOCITY EMERGENCY VEHICLES MANUFACTURED FROM JANUARY 24, 2011, THROUGH APRIL 19, 2011, EQUIPPED WITH A CUMMINS ISB, ISX, ISC, OR ISL DIESEL ENGINE. THE V-BAND CLAMP ASSEMBLY, PART NUMBERS Q187684, Q187685, AND Q187686, USED TO CONNECT THE INLET AND OUTLET CONE SECTIONS TO THE DIESEL OXIDATION CATALYST (DOC)/DIESEL PARTICULATE FILTER (DPF) INCLUDE A T-BOLT WHICH CAN FRACTURE AND FAIL WHEN SUBJECTED TO STRESS OR LOAD. A FRACTURE OR FAILURE OF THE T-BOLT MAY CAUSE THE CLAMP TO LOOSEN AND THE INLET OR OUTLET SECTIONS ATTACHED TO THE DOC/DPF HOUSING TO DISCONNECT.
Consequence:
 IF THE INLET OR OUTLET SECTIONS DISCONNECT, HOT EXHAUST GASES CAN VENT PRIOR TO EXITING THE TAILPIPE, CREATING THE RISK OF COMBUSTION AND A FIRE. IF BOTH CLAMPS FAIL, THERE IS A RISK IN SOME APPLICATIONS THAT THE DOC/DPF HOUSING MAY DETACH COMPLETELY, CREATING A ROAD HAZARD.
Remedy:
 PIERCE IS WORKING WITH CUMMINS TO IDENTIFY AND NOTIFY OWNERS OF THE RECALL CAMPAIGN. REPAIRS WILL BE PERFORMED BY AUTHORIZED CUMMINS DEALERS FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING AUGUST 2011. OWNERS MAY CONTACT CUMMINS AT 1-812-377-5000 OR PIERCE AT 1-920-832-3000.
Notes:
 CUMMINS RECALL CAMPAIGN NUMBER IS C1154. PIERCE'S RECALL CAMPAIGN NUMBER IS 74B221. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
