Author Topic: Machining pipe trolley wheels --  (Read 6683 times)
« on: January 15, 2011, 05:45:50 PM »
You guys know that I've been looking for a pipe trolley for my Host rail that I built a few weeks ago. I was going to go with a pipe trolley system, but decided that this may be just the project to design my own trolley.
Here is the Hoist project from a few weeks ago --
The pipe needs a trolley to make the hoist glide. So I chucked up two of these old iron wheels that I used several years ago to make English Wheel anvils with. IIRC I got about 20 of them from Northern Tool at the time because they were on sale for $1.50 each on a closeout.
The plan is to install some good bearings, and then cut the concave radius so that the wheel will track on the pipe.
First I chucked the wheels up and used a small boring bar to cut the bores for the bearings.
After the bores were done, I used my trusty homemade radius cutter to form the 2-1/2" radius that I needed for the rail.
This cast iron cuts very difficult because it flakes, so every now and then I smoothed it out with some emory cloth to make the surface easier for the cutter to traverse.
After about 30 minutes I was able to get my radius completed with one final smooth cut.
The finished trolley wheels with bearings installed --
Next, I'll have to build a frame around those wheels. That's a job for next week.    :beerdude:
Re: Machining pipe trolley wheels --
« Reply #1 on: January 15, 2011, 06:02:55 PM »
Not a bad idea AP, but I had a ton of these wheels sittin' around and I also have plenty of bearings. Besides, I just came up with this scheme last night and decided to hit it hard this morning. It was a good few hours spent in the machine shop -- not a bad Saturday.
« Reply #2 on: January 15, 2011, 11:31:35 PM »
As long as you're into this project, don't forget to install a self activating brake in the bottom of the trolley so you can leave it where you want to without the load following you.
Good point!! hadn't thought of that.
« Reply #3 on: January 16, 2011, 10:03:46 AM »
« Reply #4 on: January 16, 2011, 10:56:57 AM »
I guess it is to late for this
http://www.proliftsolutions.com.au/productdisplay.asp?productid=269
I looked at that trolley system Heiny. I have a friend in Australia that could get a good deal on that trolley in New Zealand. For some reason it's much cheaper in NZ (must be the taxes). Anyway, I had a boat load of these cast wheels and also the bearings, so I just went ahead and decided to go DIY style. It's more fun that way; I really enjoy working in my warm machine shop -- a nice way to spend a Saturday afternoon.
« Reply #5 on: January 16, 2011, 12:49:27 PM »
I hear ya.......   :beerdude:
