Author Topic: Frederick Flintstone’s tool finds, projects, life, universe and everthing  (Read 58474 times)
Online goodfellow
Nope -- unless you pay their ridiculous $399 ransom.
Offline fflintstone
I have been doing little stuff to just about every vehicle except getting the Corvette back on the road... :(
I have to fab some brackets to put the new to me Corbeu seats in the jeep.
I will take pictures but I mocked up this in solidworks to make the fab easier. what is not shown are the chunks of angle to bolt to the studs on the seat riser.
Offline fflintstone
this is what the factory riser looks like
Offline fflintstone
One of my calipers was sticking so I just upgraded to a powerstop set up.
Offline fflintstone
This was the seat replacement we did today.
Offline Chase100
  • Newbie
Re: Frederick Flintstone’s tool finds, projects, life, universe and everthing
« Reply #425 on: September 22, 2017, 08:18:34 AM »
Today 10JULY13, I did a few things. I got a new sign for my shop entrance.
I used my mobile abrasive cut center. I repurposed a $10 yard sale school media cart. It has plugs and a cord, and I can roll it outside when the weather allows, to keep all the grit out of the shop.
Despite being a decent welder for over 10 years, I took a MIG welding class at Lincoln electric about 2 years ago. I purchased a big MIG welder direct thru them at dealer cost. The welder sat unused until today. I needed to repair a gas pedal on my son’s go-kart and I haven’t MIG welded in two years. I wanted to run a few beads before I started the repair. I got the setting off on the first bead, but this is bead #2. Not perfect but I think pretty dam good for a second bead after two years away from welding.
As paranoid as I am about fire now I can’t believe I actually set something on fire! My welding area is not set up yet but this is inexcusable.
Nice post Fflintsone
As a relative newbie to Mig welding, (less than a year), could you recommend a good online supplier of mig wire?
I'm using 1mm in the garage.
MY local supplier is over an hour drive away.
Cheers, Chase.
Offline fflintstone
« Reply #426 on: September 28, 2017, 03:41:19 PM »
One of the ones I used didn't come up in a Google search. one of the big ones is cyberweld and I also used welders direct for reference purposes.
I use 11lb spools in my small welder and  huge ones in my big welder. I haven't changed the big welder yet.....
Offline fflintstone
« Reply #427 on: September 28, 2017, 03:45:30 PM »
Cheers, Chase.
[/quote]
also if you are not yet signed up for my buddy Jodys weekly welding video, here is this weeks video. find a link to get on the mailing list.
https://www.youtube.com/watch?v=WaLa8A5qwm8&feature=youtu.be
Online goodfellow
« Reply #428 on: September 28, 2017, 06:44:22 PM »
+1 on Jody's welding vids! The man has forgotten more than most people ever learn.
Offline Chase100
  • Newbie
« Reply #429 on: September 29, 2017, 08:30:25 AM »
Thanks fflintstone.  BRILLIANT video!  I'm following now on youtube.
All the help much appreciated.
On the wire front... i found a UK supplier with good prices.  It's all unbranded though.  You think that's ok for mig wire?
https://www.greasemonkeydirect.com/collections/welding-general
They come in kg not pounds.  5 kg probably good for me.
Offline fflintstone
« Reply #430 on: October 04, 2017, 11:06:41 AM »
5KG is 11LB. that is the common big size for smaller welders.
welding wire is rated just like stick electrodes.  the first alpha numerals are usually Er60 or Er70 sand I believe that is tensile strength of the base metal. the all the other numbers or letter mean something as well. IN THEORY an ER70S-6 should be the same whether it is from Lincoln or joe blow. However that is not always the case. sometimes the coating can be thin, and in a moist environ like the UK the wire at the bottom of the spool can start to rust if it sits in the welder for a long time.
Offline KendrickNi
  • Newbie
« Reply #431 on: November 07, 2017, 09:38:08 AM »
Great insights. It would never occur to me to think of the moisture in the air.
Offline fflintstone
« Reply #432 on: November 21, 2017, 07:45:22 PM »
With the help of my nephew and BFF we put a trans in my Matrix. with the help of my son we put new brakes all the way around on it. I now have what I hope will be a fun reliable winter ride.
Offline fflintstone
« Reply #433 on: November 21, 2017, 07:47:23 PM »
I was supposed to buy a new to me car today, unfortunately the guy never showed up at the bank wit the title  :( :(
Offline fflintstone
« Reply #434 on: November 27, 2017, 07:00:33 PM »
Well things have been smoothed out with the seller and if I ever here from my credit union, I may still get this car.
took an act of God to talk to a real person last week. 4 messages with two different people and no call back today.  :mob2:
I am only 2K shy of just being able to pay cash but I don't want to kill all my savings.
